could anyone please tell if i replace my instrument cluster does it need to be the same part number or can it be the same model n year , do they need to be coded to the ecu , thanks
hi I'm getting a fault code y3/6b1 starter lockout on the gear oil temperature sensor , is it possible to replace the sensor , if so where is it or is it part of the conductor plate , thanks
