W210 Central locking, Driver's side module
SBM
Bulgaria
S210 2000 Mercedes-Benz E-class Facelift wagon / Automatic, Petrol, 4 matic /
Hi! I'm really frustrated and mad with my car.
I have problems with my Central locking with my w210 saloon facelift. I just repaired a leak in the system in the back right door. A vacuum line was in cutted in 2. I assume the window did it when going down fully. I repaired it and it worked perfectly. Everything locked and unlocked.
Minutes later it stopped to work completely.
It doesn't lock or unlock now. The pump doesn't pump. I did a restart with the nagative battery cable. Nothing. The only thing is when I use the key it only flashes when I unlock the car but when I lock it doesn't do anything. Help.
I also have a problem in my driver side door. The whole side doesn't work (left Window up/down, left mirror adjustment, memory seat with steering wheel adjustment.)
I replaced it with another module and replaced the central console window regulation thing.
I have some pictures that I can share.
Here are the codes from my car's diagnostic
Sorry that it's not in full English
Here is translation to the words:
"ЗАПАМЕТЕН" - Saved,Remembered,memorized
"Актуален и - Current and memorized
запаметен"
TSG1 - Електронен блок за управление на предната врата от страна на водача - ! -
TSG1 - Electrical block for controlling the front drivers door - ! -
TSG2 - Електронен блок за управление на предна врата от страна на спътника - f -
TSG2 - Electrical block for controlling the front passenger door - f -
Захранващото напрежение на електронния блок е твърде високо (свръхзахранване)
Статус - ЗАПАМЕТЕН
The supply voltage of the electronic unit is too high (overpower)
Status - MEMORIZED/Saved or remembered
ESV-VL - Електрическото регулиране на седалката отпред вляво - f -
ESV-VL - Electrical seat adjustment in front, left side - f -
DBE - Таванен модул за управление - ! -
DBE - Ceiling control module - ! -
Code B1157-005
The electronic control unit has a short to ground or open Status - MEMORIZED
Code B1011
The supply voltage of the electronic unit is too high (overvoltage) Status - MEMORIZED
Code B1025
Check the CAN bus wires for a short
Status - Current and memorized
Code B1053
CAN communication with the TSG-HR electronic control unit is impaired Status - MEMORIZED
Code B1054
CAN communication with the TSG-VR electronic control unit is impaired Status - MEMORIZED
Code B1055
CAN communication with the TSG-VL electronic control unit is impaired
Code B1057
CAN communication with electronic control unit N70 (electronic unit ceiling control module) is impaired Status - Current and memorized
Code B1058
CAN communication with electronic control unit N72 (electronic control unit on the lower control panel) is impaired Status - MEMORIZED
Code B1059
CAN communication with the electronic control unit N10/1 (signal receiver and control module (SAM) driver's side) is impaired.
Status - MEMORIZED
Code B1021
CAN communication with electronic control unit A37 (pneumatic control unit with combined functions) is impaired
Code B1022
CAN communication with electronic control unit N32 / 1 (Electronic control unit for front seat adjustment with memory, left) is impaired
Status- MEMORIZED
Code B1056
CAN communication with the TSG-HL electronic control unit is impaired Status- MEMORIZED
Pneumatic control module PSE - Pneumatic control module - ! -
Signal receiver and control module SAM - Signal receiver and activation module - F -
This took me 3h to write...
I hope someone has something to help me with.
Thank you for your time :]
Here is the original diagnostic list.
Translation is in the original thread.
Forgot to add:
When unlocking the car only the front interior roof lights work. Trunk lights do not work. Rear roof lights do not work and under the door lights don't work too.
But when you open the rear doors the lights under the seats work.
Mistake in the photo with the window switches
The right window now works*
All problems solved! I removed the pump. Opened it and cleaned it. A also too the parts apart. Now it really works fast! Better than ever!
Thank me for the help I guess. 😀
