Hi
So I have a slight problem with my boot (electric)
So in the past since purchase last year the boot would unlock and open whether I press the key fob, interior switch or pull the latch on the boot, if I walked away from the vehicle while it was opening it would open and stop (any position e.g half way) as if it had lost contact with the key and frozen, when I pull on the boot latch as if I was opening when fully closed it would carry on opening as normal.
The issue now is the boot unlocks using the boot latch, interior switch & fob but does not open at all ( I have to manually pull it up) the same applies when closing .
All boot lights are fully working including the lock.
P.s I have read other post with similar issues but everything I look at included the boot interior lights, centre brake light etc also not working, or the lock or a specific switch. With mine everything is working apart from the boot automatically lifting and closing
Do I apply the same concept as other people strip the boot liner check the loom ( which is a pain) or is there anything else I need to check before I do all that (I have checked the fused)
Many thanks
Many thanks
