Hi all how's it going?
i found a topic started by david ..as below,
E220 CDI running rough (late '07),
i replied to post, but as greenmanslk reposted that the topic started back in 2015. so it may not get any more replies.
so my father as the same car as the above post, w211 e220 cdi 07 facelift. Lovely car, he's had it for about 2 - 3 months, perfect at the beginning, but started to play up.
I'm using the internet on his behalf, he good with cars but with the net not a hope .
His car was good, then it started to... When you start it from cold it's starts fine, idles fine, when you drive off it's fine, but after about 5 - 10 minute or so, when you pull up it idles rough. As if the automatic choke on a old 1980's car is stuck.
I plugged the car into my diagnostic unit (autel md508 , I think it's the 508, I can confirm that later when I get home.. sorry is a autel md805) & it gave us a code back saying glow plug #... Nothing else .
So we ordered 4 new glow plugs off autodoc.uk (great site for parts, helpful guys aswell). The parts came, put them in & guess what... Before he started the car I plugged my autel back into the car, started the car, all fine, no codes, left the car run for x minutes while we had cup tea, went back out & the car idle rough again.
It only does this after the first few minutes & when the car is at normal operating temp' it's ok.
But it should be ok all the time you know. Hence why we changed the glow plugs.
could the problem be the glow plug control module.?
or
a heat sensor some were.?
any one of you tell us were this glow plug control module is on the 220 cdi unit, please
Have any you guys any idea's please.
Thanks all.
or
Thanks all.
