Hi folks,
I hope you can help me with an issue I have been having for a while.
The car is a w211 FL E220 CDI om646.
When starting the car from cold, within 5-10 seconds the idle becomes rough jumping around anywhere from 600-800 rpm. Sometimes the car even dies when placed in D or R.
No codes whatsoever.
So far I did the following:
- changed fuel filter.
- cleaned and then even changed egr
- cleaned MAF
- changed fuel temp sensor (it was giving a pending code randomly)
Nothing cured the problem.
Also, the car has an intermittent “tremor” when stationary at the lights (cold & hot).
Any help is much appreciated.
- cleaned MAF
