Ok finally got it done and working .
A week ago i started with some new cheapie bulbs , after an age of finally figuring out how to get them in they both flickered and went out
The dashboard showed L and R dipped beam faults .
With my new found bulb fitting experience I refitted the old Osrams and that was that .
After a refund on the cheapies, I ordered some OEM Osrams which arrived yesterday .
Taking advantage of the sun .
I disconnected the main battery negative lead
For the passenger side I popped out the holding plug thingy for the coolant tank and lifted the tank to one side .
Removed the bulb electrical plug
Anti clockwise turn and the bulb pulls out .
It’s fitted with a plastic collar which need to be removed and fitted to the new bulb , sounds easy when you know how it comes apart but it took me 15 mins to figure it out .
New bulb back in 15 degree clockwise turn to lock it in place …don’t touch the bulb glass !
On to the drivers side bulb you can get access for an arm down under the bonnet release cable. You can increase room by pulling the bulkhead cables for the lights off their bulkhead pin/screw .
The best access I found was to have the back of your right forearm against the ABS unit , coming in from the side .
Disconnect the bulb power cable , anti-clockwise turn to free it . Old surround fitted to new bulb . Clockwise turn to lock it , refit cable .
Then drop the lighting housing cap down into the engine so it takes 15 mins with duct tape on the end of a mechanics extending mirror pole to fish out (very Apollo 13 ! How do you get this out of that only with this ) . Feel free to skip this part .
Battery reconnected and the Osrams now work .
