Sebs007
Hi everyone!
I’ve recently noticed my car is feeling sluggish and producing smoke. After doing some checks, I found that the turbo actuator isn’t moving at all. I tested it both with the engine running and revving, as well as with the engine off and then switching ignition to position 2, but there’s no movement. I unclipped the control arm to check if the turbo veins were stuck, but they move freely.
The actuator looks fairly new and has a G-88 label on it. After some research, I realised it's likely an aftermarket part from Amazon, not the original OEM Garett/Hella actuator. I took it off the car to confirm, and it’s indeed not the original part.
I’ve read that this issue might be linked to the swirl flap motor failing. Apparently, due to its location, it can get covered in oil from the turbo which might lead to electrical problems. I’ve also seen posts suggesting that the turbo actuator and swirl flap motor are on the same circuit, causing Fuse 44 in the engine bay to blow. I checked the fuse, but it seems fine, so I’m not sure if that’s relevant in my case.
I’m wondering what else could cause the turbo actuator to stop working, aside from the fact that it’s a cheap replacement? If it turns out to be a quality issue, does anyone know where I can get the OEM part? Or maybe someone has a spare in good working order that I could buy? I contacted my local dealer, but they said I’d need to buy the entire turbo unit with the actuator also they couldn’t give me the part number for just the actuator.
Any advice would be greatly appreciated!
