- Jul 12, 2011
- Location
- Near Salisbury
- MX5 1.8 Sport, Range Rover 5.0 SC, BMW X1
There are very few things I bother to repair / replace myself on our cars now (the MX5 being the exception as it is easy to lift and work on as access is good to most parts) but at 125,000 miles I suspect the EGR valve on the W211 will have a fair amount of crud inside it which can only hamper it's design function. I have also had a few instances of poor acceleration and hesitation which I thought was the turbo actuator but my Indie suggests is the EGR sticking and compromising airflow.
Access to the EGR on this engine is good being high up at the bulkhead on the right and it seems to be held in place by only two bolts with a couple of electrical connectors and coolant pipes being attached to it.
Has anyone removed and cleaned one on these engines? If so do you need special tools to remove the clamps for the coolant pipes and I assume there is a gasket between the valve body and housing?
Once removed is it a case of methodically picking out the carbonised deposits and for the persistent deposits are there any recommended liquids to dissolve them ?
