W211 rattle from front… suspension?!
Kompressor_Dude
Southampton
CLK350 Sport
Looking for ideas as have searched the forum and tried lots of repairs already.
W211 ‘07 E200, 89k miles. Rattle type noise from the front going over bumps.
So far have replaced:
Upper control arms (and ball joints)
Lower control arms
Lower ball joints
Lower suspension arms
Shock ARB drop-links
It was all tired as was original so I don’t mind having gone over it all, however I spent this afternoon fitting the new shocks and now the noise is worse?!
I’ve disconnected the ARB and it continued so have ruled that out. No undertray on it. Happens under braking so not pad-rattle.
What could it be and why would new shocks and ARB links make it louder?
The shock mounts looked ok, can they be visually inspected? Levered for play? Hope not as I really don’t want to test my bravery with the spring-compressor again…
Lower control arms
Lower ball joints
What about the upper ball joint that is on the end of the U shaped thingy in the top of the front wheel wells ?
This thing
if it's a rattle, it's either ball joints or drop links. Depending on the brand, they could fail prematurely. Febi ain't what it used to be,
The brake disc dust plates can corrode around the rivets and then they rattle over bumps. Easy to check, just lean in under the car and see if the back plate is secure on the hub.
This would be a noticeable tinny rattle though and you’d think potentially would have been noticed during all that recent work, but it’s what I thought of too! :)
Below is a MB service bulletin I managed to find about 3 possible causes of front suspension noise that I had on my W204. Obviously I don't know if it's applicable to your W211 but if it has the same type of passive variable damping then cause 2 the strut itself could be the source of the noise. It's not the easiest document to follow having a particular structure but I successfully used it to have the strut replaced under warranty and the noise was gone.
Front Strut / Shock Tower: By Symptom
Technical Service Bulletin # LI32-25_P-048381
Date: 091208
Suspension - Front Axle Dull Thumping Noise On Bumps
NOISES FROM VICINITY OF FRONT AXLE ON UNEVEN ROAD SURFACE
Topic number
LI32.25-P-048381
Version
1
Design group
32.25 Shock absorbers/damper struts/spring struts
Date
12-08-2009
Validity
Model 204 without code 483 (Vehicle dynamics package), without AMG; Model 204.0## #A 185017 up to * 195993 with head bearing
Reason for change
Topic extended to FA shock absorber / torsion bar linkage. / Supersedes DTB P-B-32.25/67
Reason for block
Complaint:
Dull thumping noises or metallic rattling from vicinity of front axle on slightly uneven road surface and/or repaired road surface.
Note:
Noises occur in lower speed range (20...approx. 70km/h).
Cause:
Several causes are possible:
1. Head bearings on front axle suspension struts are too stiff (Shore hardness).
Note:
Noises from the head bearing occur on more uneven surfaces and sound relatively dull.
This cause affects only a small, limited production batch! Pay attention to the VIN restriction for head bearings (EPC: "Bearing, suspension strut to
body") in Validity section! On vehicles outside the restriction range, the head bearing is not the cause of the noise and may therefore not be replaced.
2. Shock absorber
Note:
Noises from the shock absorber are audible on slightly uneven surfaces and sound rather more metallic.
3. Torsion bar linkage
Note:
Noises caused by a torsion bar linkage only occur in a very small number of cases on this model series.
Really appreciate the responses. I’ll optimistically wiggle the dust shields and see what I find but that bulletin suggests top mounts as well. It would explain why the noise got worse since new (stiffer) shocks have been fitted, and is on both sides.
I just swapped them over, but can see now that under the bump-stop there is a bearing and some other wearable parts.
Looks like I’ll be stripping it all down again… spring compressors at the ready!
I've been down this whole road on a previous W211 - not my present one - and I can only say, they are absolutely renowned for front suspension problems. Don't get me wrong - great cars, but my goodness they chew front suspension components, especailly on bad British roads.
My tip - (any maybe the only time to do this) use genuine MB ball joints. They are expensive and even hard to get sometimes, but my goodness they are twice as hard as the Chinese steel ones which are like putty. Useless.
And also, while I think about it, I've had so many springs go on various heavy engined Mercs over the years, that I now keep a correct colour-coded set in with the spare tire, and that has actually worked for me when I had one go bang in a car park once and Kwik-fit around the corner were able to instantly fit the part I already had. Sounds neurotic I know but with springs it's worth it.
Good luck . Been there done this , on a w219 , after £500 I traded the car in. :cool:
I may have found it….
This noise is coming from the steering. It’s not the U-Joint and not the inner or outer tie rod ends - so something in-between. I can’t test to see if it happens over bumps, short of ziptieing my GoPro under the car for a short drive.
OneForTheRoad, am sorting this ahead of a sale, so chopping it into a garage and letting them know what I’ve done and what’s still wrong is Plan B!
I’d rather private sale and cash buy tho, especially with all the work it’s had in the last two years (easy over £5000).
That's bad that is , mine only tapped when going over small bumps , bound and rebound , I eventually put it down to the shock absorbers.
I believe what you're hearing there is the variable steering column linkage
Fixed it!
Have to put this one down to my own stupidity, but that’s learning for you. Before taking the shocks apart again, stripping the steering down and ordering ARB bushes (the last original rubber on the front) I really pushed on the car and found I could recreate the sound. It was high on the suspension tower and when I removed the black vanity cap on the shock bolt I could see movement!
I’d tightened the bolt down further onto the threads than the old one had been, but it took another two or three full turns before it seated. Now no play. I guess these need re-checking once the weight of the car is on them.
Massive thanks for all the ideas - I’ll know where to look in future now.
A line of white paint so I don’t lose the plot fault-finding in the future and we’re done.
Fixed it!
Yeah easy and common oversight. Wouldn't hurt to hit it with a low power impact driver until just after you hear the sound get tight.
I had heard this wasn’t recommended as it can cause damage at the other end of the shock spline? No idea if that’s true or not though as never had one fully apart to see as they’re pressurised.
I’ll check them in a few hundred miles and make sure the paint still lines up tho!
It depends... Generally not good practice, but you can get away with some gentle persuasion under minimum static tension (weight of the car on the spring).
I have a 2008 s211 E350 RHD, 105,000 KMS (65k miles). Nice car came from Japan no rust. Front end left side low speed rattle annoying. Have changes all ball joints control arms, basically every replaceable part. Still got the rattle. So I swapped the shock/spring from left to right. Rattle now on right side, so it appears to be "that" shock.. Shock its self seems fine as had apart when changing upper mount. I am wondering, as it's a metal to metal sound, if the rubber insulator in the lower spring mount is worn allowing the two metal mounts to rattle when hitting small bumps? Attached is a photo of what it looks like. Also tried to find a replacement one. No such luck.
See many of these springs deform under tension. Buy a pair of Sachs same spec and swap to find out. Fairly cheap.
