silver1011
Another question for those keen on motoring DIY, when working under the car, for example draining the oil, how do you go about it? Do you just slide under, with the car on the ground, jack it up on some trolley jacks, use ramps, or some other method? I'm just wondering what the best home solution is, especially as I'm not exactly small!![]()
Buy a set of ramps, something like these. You'll need to plan to use them several times to get your monies worth...
You can get the older style metal welded ramps for less than half the price of the Sealy CAR3000C plastic ramps but I'm not a fan, it only takes a weak weld.
Then you need to make sure you've got the right tools. The oil filter lid removal tool really helps, as does a proper set of Clic-R pliers for the fuel filter hose clips. After that you're looking at a socket set and Torx screwdrivers.
Search for 'Mercedes W211 service' on Youtube, there are lots of really helpful video's showing you what to do.
For a first DIY service you should be aiming to do:
Oil and oil filter + sump plug or sump plug washer
Cabin / pollen filter
Air filter
Fuel filter
Take a look on eBay, Mercedes of Newcastle have created several genuine 'service kits' which include everything you need above including the oil.
You can check brake pad thickness and disc condition, plus lights and wipers, windscreen washer fluid, coolant levels etc. yourself.
Transmission oil, rear diff oil and brake fluid are better left to the professionals unless you're feeling brave.
