2013 w212 2.2 diesel CDI estate.
Yesterday I noticed the steering was sometimes a bit heavy at low speeds, then the low coolant light came on. Today I topped up the coolant a little bit and checked the power steering pump reservoir, which was OK. I took the car for a low speed test run for only a mile or so then when I got out of the car the driveway was covered in coolant which was leaking from under the car.
- Is there a possible link between coolant and the power steering?
- What are the likely causes for such a sudden & drastic loss of fluid?
- Ideas for a good workshop manual for the W212?
P
P
