OJLane
- Jul 3, 2014
- Location
- Holbury, Hampshire
- E350d, E350 CDI sold on at 357,000 miles, C270 is sadly no longer with us, chewed a glow plug :-(
Evening all,
Having a bit of trouble with my suspension on my E350d. A couple of days ago on the motorway I had a message come up, car with up arrow and 'Malfunction, See Owner's Manual'.
I plugged in my iCarsoft reader and it showed 'The Left Front Level Control Valve Has A Malfunction. There Is An Open Circuit' I went out to it yesterday and it seemed to have dropped a little at the rear (about 4cm gap between wheel and arch) so I am now leaving the rear jacked up as the front seems to have raised a little.
After doing some digging today and more code reading it is now showing all control valves faulty not just the front left. I'm wondering if it may be the valve block? Or is it likely to be something else? My car is my work so really need it sorted as soon as possible but can't currently afford to just throw many £100s in parts. I can't imagine it would be a strut as it is now showing faults on all corners? Could a faulty compressor cause this somehow as that has not come on since? My thinking is that the compressor is not activating due to system protection shut down but don't know. Is there another control module somewhere?
It's showing the same fault in ADS and ELC although only the rear is showing in ELC.
Many thanks,
Ollie
Many thanks,
Ollie
