Hello. I'm having an unusual issue with my 111 vito. Put simply, when I start it cold it has no power. Literally just makes 50mph at a push. But it drives perfectly. No warning lights, no stuttering just no power. As it warms up it doesn't improve. But if I park up for 5 minutes it usually drives fine. If I just cycle the engine on and off it usually doesn't fix things.
This issue started about two months ago and has gone gradually from a rare event to more than 50% of the time. When it runs well it runs perfectly. No fault codes are coming up. I had a few legacy ones for EGR but I removed it and cleaned it and not had that code recently.
Seems to me like a classic dirty maf. I unplugged the maf to drive it and it made no difference but didn't put a warning light on or flag up a fault code which really surprised me as I thought it would immediately notice the maf unplugged. I still think maf is likely culprit as I've seen the similar lack of power/otherwise behaving itself on other vehicles. But I'm thinking equally could be fuel pressure, temperature sensor etc. I'm somewhat confident that it is not in a limp mode but injecting minimal fuel due to some innaccurate sensor reading. I also replaced the fuel filter in case it was partially clogged and the cold temperature was causing the fuel to gel up and block it, however this wasn't the case.
Anyone experienced this before and want to chip in before I slap a new MAF on? (and anyone know what a gen one goes for?) Thanks
