Waterless Cooling
I have used it in my split cooling system on a E55
A few people used it on TVR's with good results, it has a higher viscosity than water, I thought it may put extra strain on the water pump this put me off using it...well its not cheap either.
Personally i wouldn't use that overpriced treacle if i was paid to...
Evans quote a specific heat capacity of 0.66 BTU/lb http://contrails.free.fr/temp/NPG+_MSDS.PDF which is about 2/3 that of straight water. Obviously water has a few drawbacks related to it's relatively high freezing point, low boiling point and corrosion hence mixing it with a glycol and some corrosion inhibitors.
The reason why all car manufacturers specifically warn against running more than 50 - 55% 'antifreeze' in water is because increasing the glycol % lowers the heat capacity, the following links have various tables showing the heat capacity, viscosity and a bunch of other stuff at different glycol strengths...
Liquid Water Properties at different Pressures
Ethylene Glycol Heat-Transfer Fluid
Propylene Glycol based Heat-Transfer Fluids
While the Evans snake oil may not boil* it doesn't raise tha max running temperature of the cylinder head or the engine oil. As it almost certainly raises the normal operating temp a little you spend a fortune (no water remember so need twice as much 'coolant') to end up with an engine that has a narrower operating temp range :rolleyes: If you get a small coolant leak while out and about you can't top up with water and carry on without wrecking your stupidly expensive 'coolant'
* at least until 375°F (190ish °C), note how similar that number is to the boiling points of neat ethylene and propylene glycol, similar deal with viscosity, specific gravity etc...
Thought of using it in my 450SE as it runs at a higher temperature, is not pressurised and is non-corrosive. Also claims to have no 'cool spots'. It is very expensive but has some real positive gains as far as I have learned and is ideal for very much older engines. Did post this very question on the forum some time ago and got some very detailed answers Try a search it should come up with it.
