Which tyre pressues CLS Sporting brake with 19's
Cherrypd
Wiltshire
E250 Convertible (A207)
Our new to us CLS has 19 inch alloys fitted with 255 & 285 tyres. The sticker on the fuel flap say 2.3 bar all round. The tyre pressure readings via the command show they are set at 2.5 front and 2.6 bar rear. Should I adjust them to the sticker values?.
Is that setting on the fuel flap for 19" tyres and light load?
If so why would you not follow the recommended setting?
Does the handbook show the same value?
Yep these are light loads and the manual just refers you to the values on the flap. Just wondering if they're high for a reason by the previous owner. I'll adjust them back down.
You could measure the tread depths across the tyre so see if they are showing under/over inflation, and adjust accordingly.
