BMole
My 2010 S350CDI AMG Sport needs various jobs doing. Because of currently unresolved issues with poor ride and vibration I’d like your help to identify two options for parts – a proper job (if I’m keeping it long term) and a cheap but adequate job (if I’m going to move it on within 12 months).
A proper job would be using parts made by the manufacturer of the genuine MB parts if they can conclusively identified, MB parts if they are demonstratively better or a similar price, or other manufacturers' parts if they genuinely are of equal quality. It would also include preventative maintenance and for example in the case of the oil cooler leak, cleaning of all parts removed and replacement of all the seals and gaskets etc. on those parts.
A cheap job would just be to cure the immediate issue using decent quality but cheaper parts.
My research so far has come up with the following manufacturers and MB prices – quote below
Is this manufacturer information correct and do you know the missing makers ?
Are the genuine MB parts better in some cases ?
Have you any recommendations for cheaper decent quality parts ?
Any recommendations for preventative maintenance ?
- Engine and transmission mounts – Lemforder. £301.68
- Oil cooler – Nissens?. £163.20 plus £11.28 seals
- Glow plugs – Beru. £128.88 set of 6
- Brake discs (and pads?) - Pagid. £183.12 front discs pair
- £111.20 pads*
- £16.20 each? wear sensor
- *MB description – parts kit brakes – so I’m wondering if this includes more than just the pads. The Pagid discs are similar in price to the MB ones but the pads are almost half the price of the MB at £66.99.
- Swirl flap motor aka inlet manifold actuator. £217.20 – no idea of manufacturer. This doesn’t need to be done but may be part of preventative maintenance done with the oil cooler & glow plugs. There are many much cheaper alternatives.
