Hi all,
I stupidly replaced the a/c condensor on my w203 with the wrong one (A2035002154 rather than the correct A2035000854) and put everything back together before trying to plug in the pressure sensor connector plug which is different. The condensor seems to be the same apart from the pressure sensor itself which has a larger diameter thread on the original. The hose fittings are exactly the same.
Does anyone know if I can just use a thread reducing adapter to fit the old pressure sensor in the new condensor?
Thanks in advance!
Thanks in advance!
