My car shows fault code P0101FB ("Mass Air Flow Sensor 1 malfunction"). Permanent Code, that cannot be erased.
Has anyone else experienced this code with similar conditions? What was the cause in your case? Any help appreciated!
I'm starting to get frustrated with the car, since it works pretty much normal, rpm might fluctuate a littlebit on idle, and acceleration does not respond as fast as usual, but still drives normal.
Is the MAF sensor faulty? is the MAP sensor faulty?
MAF does give normal readings when driving, i mean its higher than it probably should be, but it seems like the sensor works like sensor needs to work.
Any ideas?
- Intake leaks between turbo and intercooler have been fixed.
- Air filter replaced.
- MAF sensor cleaned multiple times and adaptations reset.
- MAF reading stable (~13.8 g/s at idle) - cleaning wont help, its always that reading, but the sensor itself does give like "reliable" data while driving, thats why i have not replaced it.
- Original MAF sensor still installed - from 2012-2013 i believe.
Any ideas?
