*190e Fan Switch*
stuu
Hello, my 1992 2.0 190e is overheating and my mechanic said it needs a new fan switch. None of my local scrapyards have any and I'm stuck as my mechanic can't get either.
Does anyone know where i could get one? Any help is appreciated! :thumb:
Stu.
Should be easy enough to get one new from MB? Wouldn't have thought it would be expensive.
Just pop into your local dealership - they might have one on the shelf if you're lucky :)
Failing that there are other suppliers like GSF but I don't trust them as they are quite bad at supplying you with the correct parts.
Will
My mechanic tried a MB dealer and they don't do any anymore :( I tried ebay but couldn't find any either!
Do you have a link for one? It'd be great if you can :)
Hi
if you have the chassis number to hand i will look one up for you
many thnaks
There you go - cheaper than MB, genuine part and available delivered I would think :)
Will
Update!
I ordered a part using this number: A0065459124
The switch that needs replaced is 4 pinned but I was told 190e fan switches are only 2 or 3 pinned. The place I bought it off told me that it wasn't a fan switch but some switch to do with the ecu and fan and that it was 4 pinned. I honestly don't know if its the right switch but lets hope it is :(
The fan solenoid switch is either 2 pin (switches at 100c) or 3 pin (used for auxiliary fan when aircon is fitted ) switches at 110c--- now I believe only the 3 pin switches are available but as long as you use the right connections everything will be fine
So a 3 pin fan would theoretically work in a 4 pin connection?
Do you mean the wiring plug/connector has room for 4 pins? As far as I know there has never been a 4 pin switch for the electromagnetically switched fan made by Mercedes. Usually mercedes plugs will only fit one way so you should be OK as long as no-one has changed the original wiring/plug/switch combo.
