Bobby_Rstevens
We have a 2003 W638 Vito, 112 with 9 seats and friendly name is the "venga Bus".... anyway...
Always looked after serviced but does get used a lot as my daughter is part of a dance troop so spend many a weekend cruising the Motorways to and from venues all across the UK....
Venga is a 112 with just over 170K and still very strong with hardly any rust.... but..... it's started cutting out at total random times... after start up, ticking over, low RPM, 3K I really can't isolate what invokes it...
Normally it will cut out when driving, Traction control light and glow plug light up and the van jerks with the loss of running but then just catches again and we are off but.... it's started dying now and has to be turned off/on - wired as hell....
Really noticed it smoking as well and it stinks....
Recently had the fuel line from the High pressure pump replaced as was leaking and also have the seals on the pump done and thought it was fixed....
low fuel (on qtr tank) seemed to be related but it now don't matter what amount of fuel is in it will just cut out when ever she feels like it...
Had new turbo, clutch, suspension, full exhuast, fuel filter, and loads more in the last 12mths - love her but it's getting to the dangerous stage now - losing everything in the outside lane of the M4 at 23:00hrs with your entire family in it means something has to give - trace the fault or get a VW
IT's been on Mstar twice without any errors but being unable to trace the cause of the fault/make it happen is the hardest problem.
I have a feeling it could be the injectors but before I go down this road would that fit?
I know this is an expensive root to take - could it be something like a Fuel pressure regulater/sensor - I am at a loss and really don't want to give up on the van.... it's part of the family now...
Would fault injectors not show up as a engine fault?
I have been using a Indy Merc place by me but is it time to bite the bullet and take it to Merc?
Please, please offer some advice...
Rgs
Bobby
Rgs
Bobby
