2010 b class 1.5i Petrol automatic
car has a intermittent non starting issue , normally happens when raining or cold,
So far Iv done the following
When key is turned ignition lights on but nothing happens when key is turned , no click no sound . Can anyone helps pls
1/ starter motor tested ok, directly powered from battery compartment connector
2/ brake light sensor replaced
3/ battery tests ok
4/ EIS ignition tested ok
No dtc codes
3/ battery tests ok
No dtc codes
