2012 C350 OM642 Oil Catch Can
Gnasher141
Hertfordshire
C350AMG Sport Plus CDI W204
Evening all.
So, I’ve changed the PCV but there is still oil present at the turbo inlet, and car smokes a little on boost.(so I’m told, from car behind)
my thinking is to fit a oil catch can to prevent this.
is this the way forwards?
Has anyone fitted one else fitted one? and can recommend a supplier please?
thanks
I did fit one to my E class a few years ago .
I doubt though that the smoke would be fixed by a catch can , it’s more likely to be another issue .
Even a new pcv tube allows some oil through to the turbo , that’s its purpose .
This was the thread on the t’other side
Yep agreed.....the tiny amount you usually get in a catch can would not usually cause blue smoke.....just gunge up EGR valves and intake manifolds when mixed with hot exhaust fumes.....still worth doing ....but I doubt thats your problem.
Thanks for replies
I’m going to replace the turbo inlet seal, boost pipe seals and also install a catch can(temporary/permenant) to visibly see how much oil and condensate is actual entering the engine. I was considering replacing the seals after the resonator, but don’t know if it’s a big job or not?? I will take a good look along the boost system.
Do you mean the seals in the inlet and outlet pipes to the intercooler? I changed the hoses on mine as they go soft with time. The seals are available separately from mb I think. The o rings on either end of the turbo outlet pipe are favourite too. As others have said though you may be chasing another issue.
Thanks for replies
Take care with getting a catch can that works for a diesel , you need bigger/wider connections on the can than a petrol engine .
