2013 SL63 ABC front strut boot split - replace in situ?
RussJ
Ferndown
Mercedes SL63 2013
Just had my 2013 SL63 serviced and ABC filter changed/fluid flushed.
In the health check, the Tech noted that the front ABC strut boot was split.
Given that the struts are expensive, I think it makes sense to replace the boot to keep road crap out.
I’d rather not disconnect the ABC line to completely remove the strut as its all just been serviced.
Looking at WIS, I’m wondering if its possible to replace the boot by unbolting the lower strut fixing, disconnecting the spring control arm and loosening the top strut bolts.
This should allow the old boot to be slid downwards off the strut and the new one installed by reversing the process.
Just wondered if anyone has tried this or if I’ve missed something obvious which will cause a problem?
Your theory should be correct. Although the hoses are usually rock hard and have little give. If yours are more pliable it should work.
Yes it is. I had mine done last year. I got my garage to fit it. Only took them 30mins or so with their lift.
Thanks guys for your comments and confirmation.
Did you use genuine parts or aftermarket?
Anything rubber/plastic buy OEM
