Bemajor7
Hi is there any Mercedes diesel specialist on here im having a problem getting my Mercedes c220 AMG Line Bluetec Auto 2143cc engine 2014. To Start up after changing a plastic coolant housing which also holds the fuel filter apparently these are common for leaking coolant and i bought an uprated genuine part from Mercedes anyway it wouldnt clear the EGR cooler so i decided to take off the fuel rail as this seemed like the quickest way to get the coolant housing off as it made room that way i bolted everything back together checked everything was plugged in the car started for a few seconds then died like it ran out of diesel and now it will not fire i do get a fault code some times but not all the time P0087 low fuel pressure but ive had the fuel pressure tested with a proper tester at 248bar cranking has anyone ever removed a fuel rail off these engines and had the same issue i appreciate any information anyone can give me that could help me get the car to start thanks
