rg1976
My rear door LED has failed, it was intermittent but is now dead. I took it into Listers Hull thinking it would be covered under the extended warranty but it was not. They quoted £260 to replace it and I laughed. Has anyone challenged the warranty policy, as the LEDs are not maintainable pieces of equipment as the door card needs to be removed and a panel held with rivets drilled out to get access? Failing that, what cost would an independent charge or is it a DIY job for a reasonably skilled person?
Cheers
Cheers
