DriftworksJames
evening all
I'm the proud owner of a 107k mile F reg 260E (picking it up on Saturday)
I've owned plenty of cars before but this is my first Merc and I just want to make sure I'm doing things right
First up is replacing the knocking water pump and a quick service cos it's due one in the next few hundred miles. I'm fairly handy with a spanner but am unfamiliar with the Mercedes way so a couple of quick questions if I may:
Is the water pump a straight forward job to replace or is there anything I need to know about bleeding coolant etc?
What's the recommended oil to use and should I get the oil filter from the main dealer or am I ok with the KMS/G&S/Eurocarparts equivalent?
Do I need anything else for an oil change? sump washer etc?
thanks all
James
thanks all
James
