Oct 24, 2003 #1 R rob New Member Joined Oct 23, 2003 Messages 1 Hi Guys Just trying to sort out the purchase of a 1990 tilt500SL (pre cat). Both front seat tilt forward mechanisms are jammed - any ideas? Do you know any cheap suppliers of front Discs and Pads?
Feb 19, 2004 #2 guydewdney MB Enthusiast Joined Feb 14, 2004 Messages 2,912 Location Porlock, Zomerzet Car 906 Sprinter 313cdi rob said: Hi Guys Just trying to sort out the purchase of a 1990 tilt500SL (pre cat). Both front seat tilt forward mechanisms are jammed - any ideas? Do you know any cheap suppliers of front Discs and Pads? Click to expand... try banging the seat-back with a fist, the unlock vacuum servo doofer gets stuck. happens on my CL.. lube the lock mech when you get it open. also check vacuum lines to the seat, and from the motor / pump (prob under rear seat / in boot. discs and pads - http://www.gsfcarparts.com/ or http://www.eurocarparts.com/ from eurocarparts:- ATE/TEXTAR n/a 104220260 FRONT BRAKE DISC (VENTED) 129 300SL-SL500 Ventilated £32.50 GUTTMANN n/a 104220261 FRONT BRAKE DISC (VENTED) 129 300SL-SL500 TEXTAR/JUR n/a 101220120 FRONT BRAKE PADS 124 24V £25.12 PAGID n/a 101220125 FRONT BRAKE PADS 124 24V £19.25 BWI/PEX n/a 106220010 BRAKE SENSOR Front sensor £1.30 n/a 106220011 B.SENSOR USE 106220010 Front sensor £1.47 Ventilated £23.50 from gsf M62113 BRAKE DISC-FR 300mm(BQ) 129: SL500 119.972 113.961 09/92>08/01 (>Ch.F103936) £32.00 M64019G BRAKE PAD SET-FR PAGID 129: 500SL 90>93 129+4X M64200 £19.75 (long list of others)
Feb 19, 2004 #3 Steve_Perry MB Enthusiast Joined Jun 3, 2002 Messages 3,241 Location Wales, U.K. Car CLS350CDI Grand Edition This should really be posted in the interiors or wheels section. Moving..... S.
