Hi all.
Wondering if anyone here can share any experience with timing up this horrible setup. I have had repeat problems with this.
Have followed the guides I have to work with (autodata) which seems to correspond with the WIS document I found online, and carefully followed each step.
However, when all torqued up and done, I rotate the crank twice and the timing at at the back of the cylinder heads no longer slides in, it’s very close but enough to bring up codes for camshaft timing.
I have blamed my cheap copy timing tool set for not holding the cam’s securely allowing a tiny amount of twist when tightening the bolts but just wondered if anyone else has had a similar ordeal before?
This is on a 2008 CLK63 if it helps.
Thanks, Gav.
Thanks, Gav.
