Thanks for the video. We did all that - lock tools on the front and rear of the camshafts, phaser bolts were all torqued to 45Nm plus 90 degrees. As you can see in my photo, the cam and phaser have moved but the adjuster body has not, so to me it looks like the cam has "adjusted". Nothing moved unexpectedly whilst torquing the bolts down, it was only after the rear lock bar was removed that the exhaust cam moved.
I've watched many of these videos and am certain we did nothing wrong nor missed any steps. I'm going to try rotating the engine by hand; if I can get the crank through two full rotations without issue then there's no danger to internal components so the car should be safe to start at least. That just leaves the small matter of that snapped bolt...
