Fuji
- Aug 31, 2011
- C250 CDI AMG ED125 Coupe
Thread for all the undocumented features of the 7G+ gearbox. These tips may also apply to the older 7G or even the C63 MCT box - I dont know, but maybe owners can help out and post their experiences and other Top Tips below
* Most Important 7G+ Tip : when in D mode, all gearbox-related decisions made by the driver ARE OPTIONAL. The 'box may or may not decide to change to the requested gear, and it may or may not decide to inform the driver which gear it is really using. It may change to the requested gear to see what it's like, not like it, and then change again. Do not be alarmed by this behaviour. If you really cared, then you wouldn't have bought an automatic, would you?
* When stopped at the lights, press the minus paddle. The gear number on the display changes from D to D1. If you have a passenger, you can now brag about "all that Mercedes torque" by pressing the plus paddle to set the display to D7 before pulling away smoothly in second.
* The flappy paddles have nipples! The plus paddle has an "outie" and the minus paddle has an "innie". The nipples can be found about half way along the back of the switch. This way, careful nipple fondlers can always know which paddle they are pressing, regardless of hand location, without having to look. If only MB had put this much thought into placing the paddles correctly... fixed to the steering column.
* When hooning it around the local housing estates using the paddles to manually override the 7G+, rally driver stylie, you may find you have to occasionally stop for animals and/or pedestrians. Don't worry, as the display will helpfully continue to show the last gear that you selected, regardless of whatever the gearbox is actually doing. See "Most Important 7G+ Tip" above.
* When changing from R to D, the car automatically engages "hill start" - maximum braking - to prevent damage to the gearbox. However, if there is any momentum *at all* when this happens, the brakes will bind. This prevents D from being fully engaged, and causes the brake pedal to also be locked in place. Simply pop 'er back into reverse and pretend it never happened. (Bonus tip: a swift double-press of the brake pedal is an easier way to engage hill-start).
* For those with the Dynamic Handling Pack (DHP) : pressing the "M" button under the gear selector is a cool way of having an "M" shown on the display. Press it again, and the "M" disappears.
* Those without the DHP installed additionally benefit from being able to have an "S" shown in the display by pressing the button under the gear selector. It may feel like the gearbox is shifting quicker when the "S" is displayed, however this is simply a placebo effect and it will not help you win any races or get home any quicker.
* Situations where kickdown is needed are best avoided unless you either (a) need a new pair of trousers or (b) are the kind of person who likes to go BASE jumping at weekends.
