Vslowone
Hi, i am looking to buy a w203 convertible, would prefer one with the manual option, can anybody tell me which engine size and years these gearboxes where fitted, thanks martin
i don’t think the 203/209 generation of cars had paddleshifts, or even buttons, I’m pretty sure that those cars which did have the manual option use the gear ”stick” for manual shifts, ie forward and backwards to select drive modes (ie P, N, D, R) and right and left to change up and down gears.As far as I know, on the C-Class, the 7g box was fitted to the W204, but not to the W203 which had the 5g box until the end of the model production in 2007.
You may be referring to the A209, introduces in 2002, which was a convertible based on the W203, or its replacement the A207, which was a based on the W204, and introduced in 2010.
Of the two, I don't believe the earlier W203-based A209 was ever fitted with the 7g box. But you can try, maybe one of the very last models (2008/2009) had it, I don't know.
The 7g box with the manual mode and the paddle shift option will have a transmission programme button with 3 options, E, S, and M (Economy, Sport, and Manual). 7g gearbox with no manual mode option will have a button with only two options, E and S, and won't have the gear shift paddles behind the steering wheel.
IIRC when we bought our S203 back in 2005 it's bigger brothers the C320 and C350 were available with the 7gAs far as I know, on the C-Class, the 7g box was fitted to the W204, but not to the W203 which had the 5g box until the end of the model production in 2007.
Only the C55 had steering wheel shifters and that was coupled with the 5gi don’t think the 203/209 generation of cars had paddleshifts, or even buttons, I’m pretty sure that those cars which did have the manual option use the gear ”stick” for manual shifts, ie forward and backwards to select drive modes (ie P, N, D, R) and right and left to change up and down gears.
The AMGs 55 did, initially buttons but in later models, aluminium levers behind the steering wheel. This was extended in later CLK to all auto 7g modelsi don’t think the 203/209 generation of cars had paddleshifts, or even buttons, I’m pretty sure that those cars which did have the manual option use the gear ”stick” for manual shifts, ie forward and backwards to select drive modes (ie P, N, D, R) and right and left to change up and down gears.
My W203 coupe 2006 has shifting buttons behind steering wheeli don’t think the 203/209 generation of cars had paddleshifts, or even buttons, I’m pretty sure that those cars which did have the manual option use the gear ”stick” for manual shifts, ie forward and backwards to select drive modes (ie P, N, D, R) and right and left to change up and down gears.
I think the OP is looking for an A209 with 7g automatic transmission and manual mode.Vslowono If want manual gears, get a Chrysler Crossbow, it has MB running gear with manual option.
I probably misunderstood the OP by thinking they wanted a manual gearbox car rather than an automatic with flappy paddles for 'manually' changing gears.
I suppose the clue was in the title of the thread but, in my defence, I was influenced by the response in post #2 above.
I have an S212 with the 7G+ gearbox which has flappy paddles. I have played with them a bit when I got the car first.
You press the paddle to change up/down, then the gearbox decides if that is a good idea or not, then, if it agrees, it actually does the change.
It certainly isn't a split second change like it is on a VW DSG.
When you do one gear change the gearbox thinks you want to take complete control so it won't change gear automatically until you flick it up to 7th or the car slows down to a halt.
The novelty wore off very quickly and I now never bother with the paddles.
