'96 Mercedes C Class door speaker PLEASE HELP!!!
babz
Newcastle Upon Tyne
1996 Mercedes C180
hi, ive just noticed that the front passenger door speaker isnt working. ive checked the connection and it seems fine. ive took the speaker out and tried it on the drivers side and it works!
could it be a fault with the wiring?? PLEASE HELP!
might be the main unit/cdplayer, broken speaker element or a connection failure somewhere check if the balance on your player is correct so it is not just sound on one side
ive played around with the balance/fade but no avail. the rest of the 7 speakers are working fine aswell, just that one isnt. the speaker itself works fine because ive tested it. must be a didgy connection somewhere?
yes i think so try check the connections to the speaker might be the wiring or a bad output on the player?
