Hello! My C200 as an automatic climate control. Are any tricks for it? Press 2 keys to obtain a "new funtion"? Press 1 key for X seconds and so on...
Is this what you're looking for?
Applies to the W210, W208 and W202 with digital climate control display:
With a running engine, press the "REST" button for 5 seconds
Use the "Auto" button or the "+/-" button (depending on model) for the following readouts:
01 = In-car temperature sensor
02 = outside temperature sensor
03 = left heat exchanger (heater core) temp sensor
04 = right heat exchanger sensor
05 = evaporator sensor
06 = Engine coolant temperature
07 = refrigeration pressure in bar
08 = refrigeration temp sensor
10 = Blower control voltage
11 = emissions sensor (Bsp.: 3.1 = 31.v)
12 = sun sensor (Bsp.: 4.2 = 4.2v)
20 = aux cooling fan control 6.1 = 6.1ma (max 10ma)
21 = engine speed RPMs x 1000
22 = vehicle speed KPH
23 = Circuit (Bsp.: 99 = 99% of battery voltage)
24 = BATTERY VOLTAGE (Bsp.: 12.5 = 12.5v)
40 = control module version software status
41 = control module version menu hardware status
42 = control module variant code 1st number
43 = variant code second number.
Press "Rest" to leave the menu.
