A140 Auto
roadrunner
Hi
Car is an A140 classic on an x plate
Problem!!!!!
When starting off engine revs freely to 3000+ but the car moves off at a snails pace, as it picks up speed it will change up and thereafter no problem until you come to a stop and then the same again, if you stop on a fairly steep gradiant the the car will not move forward in fact it will roll back(the engine is still at 3000 rpm) reverse is fine? I took it to our local MB specialist to do a code read and he has identified an ECU fault. I contacted the main dealer in Glasgow who agreed that a fault in the ECU could cause this problem however they have noticed an increase in damaged wiring in the loom between the ECU and bulkhead.
The cost of a new ECU is around £1000 including coding, I have seen several companies advertising that they can repair the ECU for around £300, has anyone gone down this route?
Any help or advice on the above would be much appreciated
Regards
John
