Hi All,
Having been out of the Benz club for a few years after selling my CLS55 I have been starting to get a hankering for another, though not a CLS55 this time round, I am thinking SL55, whilst this brings me the lovely engine etc what it also does is expose me to the fantasy world of ABC suspension! I am an engineer, I weirdly like this sort of thing so I am not going to prattle on about what are common problems etc etc, I have no doubt that this forum is absolutely full of information on that!
What I am after and what I can not find is a systematic list of what to attack on it and in what order, I would like after a short while to have a mostly brand spanking new ABC system that I can have serviced and look after without living in fear of many of the problems encountered by fixing it as you go along.
So far as I can work out based on posts etc it would be:
1. Make sure oil and filter are changed, flush system at same time to make sure no debris or any sort anywhere, check system and replace anything that even looks like it may be even weeping a little.
2. Replace Pulsation damper and pressure valves.
3. Rebuild valve blocks.
4. Replace Front and rear pressure reservoirs.
5. Replace Oil cooler.
6. Replace Pump and all pipes, new oil change with filter and flush. Make sure pipes are heat shielded and protected when reinstalled.
7. Keep on checking the dampers because you can see those and replace the moment I need to.
The last question, is this too obsessive, or is it the right thing to do, what I am trying to avoid is one component going wrong and breaking the whole damn system.
Also, it is good to be back, I am off car shopping this weekend, there are a few about at the moment, hopefully I get lucky!
All the very best
Tim
All the very best
Tim
