PJH said:Your vehicle is illegal because the brakes are not working correctly. As Ian says, it may be a simple fix but you should get it put right A.S.A.P.
I saw a programme a few years ago, possibly Police Camera Action, it showed a pic of a Ford Granada failing to stop at Red traffic lights, all four wheels locked up.Dieselman said:I'm not sure it's illegal but it will certainly fail an MOT test. The brakes are working the ABS isn't.
Parrot of Doom said:Personally, I'd just pull the bulb out of the dash, that way nobody will know its got ABS.
Besides, ABS doesn't make you stop any faster - it just helps the driver retain steering control of the vehicle under braking, by stopping the wheels from locking.
Brian WH said:ABS DOES stop you faster it stops the brakes locking up, thus maintaining maximum friction on the road and stopping in less distance than conventional brakes.
front fog lights and they do not work it is a fail
