Hi , I am looking for a abs pump for my ml , I have the fault C1401 showing on a diagnostic check , I have tried changing the k25 relay , brake light switch with no joy lights on dash still illuminated , I'm going to try and access the pump next w end and have a look at the pump it's self , I have read on forum about changing the brushes , also does anyone know if the jeep grand cherokee 2.7 crd uses the same pump as I thought I might strip it down and use some bits as these pumps on ebay are going for around £30.00 any advice would be greatly appriciated , I found a company that refurbish the unit but my ml is used daily and this will take between 5 to 1 days.
Thanks Terry
Thanks Terry
