Hi guys, i have a GL 450 2007 and I am having issues with the ABS, first issue was i was driving along at about 20-30 MPH little yellow triangle came on and all the brakes applied brought me to a dead stop in the middle of the road!
Get it on the scanner (DCI150) and found the front left wheel speed sensor had an open circuit, so replaced that. take it for a test drive and go above 3 MPH all the brakes apply again, back on the scanner shows the rear right is intermittent so replace that as well.
Clear all the faults, start off on a drive, and get ABS fault and lights on the dash, but the car will now drive and change gears. So back on the scanner and bring up the faults again front left wheel sensor, clear the faults, and go to the "flight recorder "on the DCI scanner load up the 4 wheel speed sensors onto the chart go for a drive and the chart shows that every so often there is a bit of a dip for a split second on the front left .
Again clear the faults and load up the 4-wheel speed sensors onto the chart, notice there is an additional chart for wheel speed left and right so load that up as well , off for a drive ABS warning comes back on, checking the charts there is a dip for a split second on the front left but the wheel speed left starts off ok then flat lines the wheel speed right chart is up and down with the speed.
Is there a separate speed sensor for the wheels on the front?
anybody got a wiring diagram or where can i get one
should i be looking at something else?
