Aerila splitter for a W203 DAB radio?
punkieys17
I'm about to fit a Revo DAB adaptor to a Mercedes C-Class W203 2003 model.
The car uses the rear windscreen for its radio aerial. Has ayone used a splitter to supply the DAB feed - if so what has been their experience. This is my preferred solution as it keeps the car "clean".
The car wil be used for a commute between Surrey and london - so reasonable signal strength all the way.
If I have to go with the glass mount aerial then what suggestions would the forum members make.
If you split the lead you would be better off with a split amp to keep the signals clean, you cant split the the lead without one successsfully
