air con 320e
stevend
somerset
c 270 cdi, CLK 230k I miss this car but not as much as I miss my E 320 coupe.... and now an ML
I have a 1996 320e. and have had it for about 6 months. I think I love it. However, air con or climate control is driving me mad. It never seems to get cold enough. I took it to a local garage and as usual they said it needed gassing. So £70 later it was gassed. But it still does not get that cold. It cools the car, but other cars I have had had real cold air coming out of the vents. Anyway, I went through the forum ad I see that the fans are supposed to come on. Well on mine they have never been on even after a run or when very hot outside. The engine temperature has always stayed stable. I tested the fans by bridging the plug to the temperature sender and they both come on. The air con pump continuingly cycles on and off. I see from the forum the there is a sender that turns the fans off and on. Is there a way of testing that and what sender am I looking for.
I hope someone can help, even though the weather is starting to cool I still want it to work.
steve
Hi Mate,
Its seem like a bloked dryer or your compressor has failed to pump the gas. For the best and friendly :) advice and service you can call my friend John 0208 4502997 Air con specialist Based North London. His rates are very reasonable.I get all my work done from him. Just mention my name to him Mr Singh.
