Air vent lights
Tan
Woodford Green
W140 S-Class, Porsche Cayenne and Porsche Boxster
Hi
After finally getting around to fully installing my Origin B2 today, I have noticed that the light that illuminates the left air vent controls is not working. However, there is light coming from the back of the switches on the left so I think that I may have knocked the bulb out of place.
How do I get to this area to change refit the bulb / change it.
Regards
Tan
My left front passenger air vent wheel (the one that can shut the vent off ) has also stopped illuminating (white line on wheel that is), is it a bulb and how do I remove the vent??
Remove the wood trim above the glove box by prising the end near the door then sliding left, then the glove box, there are screws in the base and top flange, pull glovebox out and then you can get to the vent.
Thanks for that, but do I need to remove front passenger dashboard speaker cover first?? The wood trim seams to go under it at the very end (far left of wood strip).
