stephenmercedes
This morning, the red LED on the Econ button remained on, no matter how many times it was pressed. On phoning my local indie, they advised that the likeliest cause was that it needed re-gassed as this was an indicator that the A/C had shut down, which it does on running out of gas to protect the system.
Went to KwikFit to get it re-gassed at a very reasonable £59.95. The machine they have vacuums the system, then tests for leaks, then re-gasses it. I was told though that the 'leak' test only really picks up sizeable leaks, if it's a pin hole, or a dodgy seal, it may pass.
Now, I had the A/C repaired just a year ago with a new condenser radiator. So, is it likely I have a very small leak, or may it be a sensor issue?
