altenator belt
tolly
Ireland
2001 W210 E200K Avantgarde
as the name states the belt is slipping ;(
i did it before on other cars but not a merc, could do with abit of help to pin point the tensioner bolt cuz i havent the time to root around in the engine bay
Cheers
Look under favourites, click on russian epc site, click on your model of car 202, then engine then cooling system.
Lynall
the adjuster is automatic its on a little ram! once its losse its loose and will need replacing!
Yep, I think it will be self adjusting. You might want to check the damper and replace at the same time if required.
