Gallon
Hi all,
anybody know if you can retrofit the analogue clock on a W205 fitted with Audio 20. ie when you set the time on the Audio 20 will it also set the time on the analogue clock. I know it's not a problem if you have Comand.
I'm aware that you have to connect to the Lin bus in the front SAM.
