Engineering Menu on W176
nikolasr200
Athens
W176
I have a W176 that originally came with NTG 5.1 Audio 20, and later on I had NTG 5.1 Comand retrofitted by a specialist.
My question is related to the "engineering menu" and access to it.
When I had Audio 20, I could enter "engineering menu" by pressing "hang up + 1 + ".
The resulting screen looked like this:
IMG_5610
However, this combination does not work on Command. I can only access the menu called "Dealer" using the combination "hang up + 7 + 9", which looks like this:
IMG_5609 Medium
Does Comand have an engineering mode? And if so, how can someone access it? Is any activation required?
Thank you in advance!
At least someone that could confirm that can access engineering menu on an ntg 5.1 comand, on w176, so that to verify that there is some restriction on mine ??
I had crossed in the past but now that I went through it again I realized that the ts describes the exact opposite problem. He/She can access engineering menu but not dealer.
Someone suggests that using vediamo someone can enable engineering menu. So it can actually be enabled / disabled, and for some reason is disabled in my case..
You can't access it with key presses.
