ok so i just brough this c class avangard estate , its a 270 cdi , however when i brought it it had a command fitted with a white screen , and the audio kept going off , no orries i thought ill junk it , and fit my trusty Jvc Xhad touch screen jobby ,
fitted it with a conects 2 can bus adapror for ign live , reverse and light on signal , it also douse the wheen controls ,
i have no optical cables in the car that i can find , nore can i find any amps , i have looked in the boot were the bass box would go and behind the fuse box ,
the issue is the sound keeps going off the car is triping the amp in the jvc ,
this morning i got a DMM out and went a the wiring to see what i could see , i found the the left hand speker reads 1.2 ohms to eath one one of the pins and .3Meg ohm when the ignition is on ,
this test was done from the connecter that goes to the radio with the radio disconected ,
accros the speakers i get 5.2 ohm on the froms both the same and 6.4 on the rears both the same
i have no sub fitted ,
any thoughts , am i missing a amp in the car some were
also any clue how to set the clock ?
