MohammadSofiyudin
Hi this is detail of my car
1984 280E Euro A/T Engine 110.988 RHDTransmission 722.300 Is there anyone can help me to adjust my shift point? My 1-2 would not shift before 3.500 rpm, and it will shift if i let go of my pedal, i already checked:
- modulator pressure per spec 2.8 bar after 1981
- throttle linkage per spec 345mm connecting rod (2) to slotted lever
- connecting rod from throttle valve to guide lever 75mm
- checked vacuum modulator with no leak
- checked atf level are below max when hot Seems i cant adjust my bowden cable because there is no nut adjuster. And the shift quality are harsh on 1-2
