Hi Folks
I've just retracted my towbar with the adapter converter plug for light board and it jammed. This is not the first time and resorted to helping it slightly by hand.
this time though the warning message appears once deployed out "Trailer coupling Check lock" thing is I need to use it and understand Merc dealership will be useless for an OEM part (Bosal auto Towbar) and as already discovered will only fit them not repair them. the reason I'm probably going to use it as it seems to lock in position fine and makes the usual clamping grinding noise at the end of the process. After standing on it and jumping up and down it doesn't move a bit and seems very solid and parallel to back bumper as it should be.
any help to fix this or advise asap would be greatly appreciated.
