B-Class w245, sensor error codes?
villy skov
Denmark
MB W245 B-class 180 CDI and MB A168 A-class 160 CDI
I have a w245 from 2010, diesel 180 CDI, and it is in limp mode.
I recently cleared the error codes using the iCarsoft system scanner, but after driving the car, it has come up with a number of new errors. Now the car is in limp mode.
I’m facing a lot of error codes, and I’m unsure where to start troubleshooting to get the car back to normal. If anyone has any advice on how to proceed or knows what parts might be causing the issue, I would really appreciate your help!
Thanks in advance!
Component M55 (intake port shutof actuatormotor) has Short circut to ground
Component Y100/2 (Boost pressure regulator) has Open circut
Component M16/5 (Throttle valve actuator) has Short Circut to ground
The signal voltage of component B19/8 (Dwonstream TWC [KAT] temperature sensor) is to low
The signal voltage of component B5/1 (Charge pressure sensor) is to low
The soot content of the diesel particulate filter is to high
Component B60 (Exhaust back pressure sensor) has plausibility error
The heater for component G3/1 O2 sensor downstream TWC has short circut to positive
Component Y31/15 (Exhaust gas recirculation hot gass pressure transducer) has Short circut to ground
Component Y31/14 (Boost Pressure control pressure transducer) has Short circut to ground
The Loser limit value of component B2/5 (Hot film mass air flow sensor ) has been reached
