hi ive just brought a 06 b180 cdi se w245 and noticed when checking the oil level which was ok , and with to bonet open i turn off the engine and restart and all is well then after aprox 40 seconds it rattles like a solinoid kicks in and activates something its like a noisy fan bearing,but its not a fan and i have sent it back to the dealer i got it from and they thought it might be the diesel pump but this was removed and tested and ok, they took the belts off run it up still there ! and has had the cat checked along with the turbo as the sound sounds like its from the front of the engine and has a slight rotating noise its not a heat sheild ! it does it hot or cold and every time you switch it off and back on and at exactly the same time every time , if anyone has one or a b200 could they have a listern its not loud and cant really be heard inside you have to have the bonet open the car runs very well and has no lack of power etc, im starting to think its normal as it does not effect the car but if anyone can help or confirm this would be great,
